Leaking shower head
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rachelle224, Mar 12, 2006.
  1. rachelle224
    rachelle224 New Member
    Mar 12, 2006
    My shower head leaks when the water is on to the tub. It leaked a lot, so the water would spray you in the face if you were in the tub and turned on the water. It's two handled with a pull-up diverter. So I replaced everything, the stem, seat, the diverter. Everything except the pipes behind the wall is new, and the flippen thing still leaks. It's not as stong of a leak as before but it is still leaking. Do I need to just go buy a whole new one or is there something I am missing. Thanks
    Rachelle
  2. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    Before you replace it all try this:
    Pull off the tub spout so you just have the piece of pipe coming out of wall.
    Turn on and off both hot and cold valves, NOT TOO HARD 'cause it will shoot across tub and splash everywhere . See if a screw or something else foreign comes out of the line. Check inside new tub spout and then re-install tub spout.It is my guess that something is blocking the full flow to the tub spout.
    Cal
Similar Threads: Leaking shower
Plumbing Forum, Professional & DIY Advice water leaking shower room condominium Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Leaking tub/shower. Please Help With Your Expertise!! Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Help!! Leaking shower Apr 18, 2015
Plumbing Forum, Professional & DIY Advice Solvent welded shower drain is leaking Mar 20, 2015
Plumbing Forum, Professional & DIY Advice Shower leaking?? Mar 1, 2015
