Leaking shower drain
Discussion in 'Shower & Bathtub Forum & Blog' started by dergas, May 17, 2007.
  1. dergas
    dergas New Member
    May 17, 2007
    Walpole, MA
    I have installed a new fiberglas shower with new brass drain. Rubber and fiber washers are installed correctly and the seal around the pipe seems OK. I can't seal between the shower floor and brass drain and it's leaking. I have easy access to it right now below in my garage. Is there another sealant needed? Nut is tightened as much as I dare.... Thanks for your help.
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    If the top piece of the drain is flanged, then you need to use plumber's putty under the flanged part to get a water-tight seal.
  4. dergas
    dergas New Member
    May 17, 2007
    Walpole, MA
    Thanks - I'll take it apart and give that a try. Appreciate your response.
Similar Threads: Leaking shower
Shower & Bathtub Forum & Blog Suspicion of shower leaking Mar 8, 2017
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Remodel shower stall kits prone to leaking? Nov 8, 2016
Shower & Bathtub Forum & Blog New home - leaking shower arm inside wall Oct 26, 2016
Shower & Bathtub Forum & Blog Shower drain leaking Aug 13, 2016
