I was helping my father-in-law out with some home repairs over the holidays. After we were done he lead me to the mechanical closet in the basement where the water main comes in.
The main comes in vertically through the concrete slab and after going through a shutoff valve and an odd meter arrangement enters a Watts pressure reducing valve. All the pipe is copper and everything for a couple of feet below the input of the Watts valve has a nice green patina.
There is obvious evidence that the union fitting at the valve input has a slow leak. I'm thinking I can fix that with some pipe dope on the threads. Should this do it?
However on closer inspection the corrosion is also evident above the union, but more isolated. I think I narrowed it down to a plug on the side of the valve opposite the bell shaped cover (would be the bottom if the valve were installed horizontally). The corrosion here is mostly green as well, but also has some white fluffy corrosion. I think this plug may be for a strainer?
The house was built in the late 70's and this is all original.
Is there any way to repair the leaky Watts valve or am I going to have to replace it?
Also, the original installation was done with no thought toward this eventual situation. The Watts valve is in a stud bay open on the mechanical closet side, but sealed with drywall behind it. The valve is pretty snug against the drywall and the plug side of the valve is within an inch or less of a stud. The input side of the valve has a union connector, but the output side is female pipe threads (with no room to rotate the valve off of these threads b/c of the drywall and stud ). If the plug leak is repairable I may have to remove the valve to do it which means I'll have to cut the pipe on the output side and intall a union fitting there for the reinstall.
Thanks in advance for your help. If I can get this resolved my father-in-law will really be impressed.
Thanks,
Joel
Thanks,
Joel
