Leaking outdoor faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by coachjerry, Sep 12, 2005.
  1. coachjerry
    coachjerry New Member
    Sep 12, 2005
    I have a 30+ year old Mansfield frostproof outdoor faucet which is slowly dripping. I was able to remove the rusty screw which held the blue handle on to the valve, but have been unable to remove the handle. I have only about 2 inches between the back of the handle and the outside wall of the house and have tried pulling, prying, twisting, and cussing...all to no avail. The handle wiggles in place but won't move off the valve stem.
    I've used WD 40, tapped it, and cussed some more...still no success.
    Any ideas?
    Coachjerry
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'd suggest you consider just replacing the valve with a new one. This old fellah has served his time. You will need to work from the inside where the faucet connects to the water supply line. You'll need 2 wrenches working opposite directions to keep from twisting the supply line connection. For what it's worth, WD40 is not a good penetrating oil.
  4. coachjerry
    Sep 12, 2005
    Thanks Gary
    Thanks Gary, I'll consider replacing it. Thanks for the WD40 tip too. I've always used it as a penetrating oil with good results. Do you have a specific recommendation that's better?
    Jerry
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    loose
    Penetrating oil never helped me.
    Depending what your working on Heat will help.
    Usually it's patience and leverage that helps. Just back it up.
  6. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I use penetrating oil all the time with good results, great for dissolving calcium or loosening up the bonnet nuts on 1300 series deltas and up. There is a product called "Free All" and it is usually around $10 a spray can, has a very strong smell to it and will probably work in your situation. I don't know where you find it but do a search on the net. I do follow the logic of replacing it, but sometimes that is difficult in some situations.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    I agree with Plumber 1. I've never relied on penetrating oil on plumbing fittings. Rusty nuts/bolts perhaps, but even then I usually use a light weight oil aka sewing machine oil, and let it set for awhile. Main thing with pipes is to use two wrenches to keep the piece not being turned from twisting.
Similar Threads: Leaking outdoor
Plumbing Forum, Professional & DIY Advice Leaking outdoor faucet attached to house Jan 6, 2017
Plumbing Forum, Professional & DIY Advice A different outdoor faucet leaking indoors deal Mar 10, 2014
Plumbing Forum, Professional & DIY Advice anti-siphon valve is leaking on outdoor faucet bib...trouble identifying make of bib Jun 27, 2011
Plumbing Forum, Professional & DIY Advice Leaking outdoor faucet; or worse? Jun 15, 2011
Plumbing Forum, Professional & DIY Advice Leaking Outdoor Faucet? Sep 21, 2009
