Leaking noise on Toto
Discussion in 'Toilet Forum discussions' started by Sofa King, Mar 12, 2008.
  1. Sofa King
    Sofa King New Member
    Jul 10, 2007
    I have the Guinevers and when I add liquid to the bowl ie. urine i hear a noise.
    Is this a constant level in the bowl and any extra goes down the drain? i never experienced this on my other toilets. One toilet it is a constant sound for about 5 seconds when a pint is added, on the other about four to five short bursts for the same period of time (5 sec). the third toilet is removed but it was doing the same.I just hope the rings were installed properly.
    TY in advance
    Sofa King
  2. Terry
    Aug 17, 2004
    It's water going over the dam, so to speak.
    When water is added, the overfill will go over the top bend.
    Since the trapway is plastic, you hear it more.
    After a while of using one, you will forget to listen for it, much like a clock ticking.
  4. ncplumber
    ncplumber Master Plumber
    Mar 7, 2008
    Indian Trail, NC
    Terry is right. I installed a Toto Vespin that did the same thing and drove me AND the customer to the brink of insanity... until we discovered it was the plastic trapway. It should stop after a moment. If it doesn't, check for a faulty flapper.
  5. Sofa King
    Jul 10, 2007
    Yeah, I told my plumber who installed them that they are the best and he laughed at the plastic trapway. I thought they advertised a glazed 2/18" trapway, prolly up higher on the toilet lol.
  6. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Department of the Army Civilian (DAC)
    Maryland
    This thread answered my other question.
    Another question...can you can tell me how to stop the Nexus tank from rocking/wobbling please let me know. This tank seems to float with just the tank -to-bowl gasket and rocks easily if you lightly poke at it. I do have a 1 3/4" gap between tank and wall that I'm going to put a piece of wood so the tank will stop rocking but if anyone has another suggestion please let me know.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Tighten the tank bolts! they are too loose. The tank should almost touch the bowl.
  8. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    I'm slowly tightening them as the gasket settles - they almost touch now. I'm also hoping this fixes the small leak coming from the gasket / flush valve nut area. Thanks.
Similar Threads: Leaking noise
Toilet Forum discussions Toto UltraMax II Sounds Like It's Leaking Then Makes Strange Noise May 6, 2013
Toilet Forum discussions Toilet Ring Leaking in Rental House Jan 3, 2017
Toilet Forum discussions Flushmate external regulator leaking Nov 18, 2016
Toilet Forum discussions Drake with a leaking flapper Nov 9, 2016
Toilet Forum discussions New Korky 528 Fill Valve looks like its leaking...bubbling Nov 9, 2016
