Leaking New Toto Drale II C454CEFG
Discussion in 'Toilet Forum discussions' started by DanMcD, Aug 21, 2013.
  1. DanMcD
    DanMcD Member
    Jun 19, 2005
    Dayton, OH
    I had my bathroom remodeled with a new Toto Drake II toilet. The installer had to keep adjusting the center flush valve nut to get the tank to sit tight and not rock. It seems to be a very stiff rubber gasket that seems to flatten out some over time. He finally got the tank to not rock, but it sits on the center and right porcelain feet, but not quite touches the porcelain foot on the left side.
    In any case, the tank still leaks and it seems to be coming from the right side tank bolt. He took off the tank and re-seated the bolts but it still leaks at that right side bolt.
    Why is this so hard to get it right? Could the Toilet be defective?
    Advise?
  2. Starwarsith88
    Starwarsith88 DIY kid who loves toilets
    Aug 20, 2013
    Sparta NJ
    That's strange, it could be that the tank is screwed up possibly, make sure the toilet is completely leveled. If the toilet is un level, try shimming it, the tank is leaking, try replacing the gasket, and if it keeps leaking, then you will have to get a new tank.
  4. Terry
    Aug 17, 2004
    http://www.terrylove.com/forums/sho...T454CEFG-2-piece-toilet-written-by-Jamie-Love
    Make sure the large flush valve nut is tight.
    There should be no metal washers in the tank.
    The rubber washer is placed on the brass bolt, and dropped through the tank. The metal washer goes on the outside of the tank, and is snugged on by a nut. Doing it this way also makes for a firmer installation. I don't worry if the tank moves some.
    The tank may not pull down all the way into the cradle. Not a big deal.
    Follow the instructions in the link above and all should be well.
    We've installed thousands without problems.
  5. Starwarsith88
    Aug 20, 2013
    Sparta NJ
    I think that kohler has never been good with the bowl rinse on any of their toilets.
  6. Terry
    Aug 17, 2004
    I can't picture what that would look like.
    The tank sits on the bowl, hopefully the rubber washer on the flush valve would be placed "on center" with the hole in the bowl. And then snugged down.
    [​IMG]
  7. DanMcD
    DanMcD Member
    Jun 19, 2005
    Dayton, OH
    Terry.
    He did all the steps just like your said. His next step will be to re-check the entire tank (including the flush valve nut again), then get a new set of rubber washers to place on the brass bolts. FYI, there are no metal washers in the tank. The metal washers are on the oputside of the tank.
  8. DanMcD
    DanMcD Member
    Jun 19, 2005
    Dayton, OH
    The tank is level. We will check the tank for any hairline cracks, and if none, replace all gaskets and washers. Then replace the tank, if needed. I’m not too happy about all this.
  9. Terry
    Aug 17, 2004
    Unless the tank is cracked, that should be enough.
    In "rare" occasions, I've pulled the flush valve out of the tank, and checked for smoothness where the flush valve drops into the tank. A small speck of clay can lift the vinyl seal enough to allow a leak.
    I've always been able to use the gaskets. At the worst, check for smoothness or snuggness.
    If there is a crack, all bets are off.
  10. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Except he can't seem to install a Drake II tank without leaks. He shouldn't have had to adjust the center flush valve nut. If it's leaking around a tank bolt, then that's where to look. By double-nutting, that particular process is what creates the seal between the bolt head, washer and tank. That connection is what needs to be checked. Maybe lightly-sanding around bolt holes, then applying the right amount of torque to the nut on the tank bolt outside of the tank should create the proper seal there. Once that's done, then you attach the tank to the bowl with the other nut and metal washer. Getting that tank level requires a little patience, and willingness to tighten slowly while holding in place, moving smoothly and evenly down while alternating between bolts and watching how the three points of contact converge. You shouldn't need to "shim" anything. What he's talking about is a "solution" to a nonexistent problem. You shouldn't need a different tank-to-bowl set with Toto, but if they have been stripped or something by now, then get a good one, with two metal washers, two rubber washers and two nuts per bolt, like this one (not necessarily this one, but this array of quality items):
  11. Terry
    Aug 17, 2004
    We've never shimmed a tank to a bowl on a Drake before.
    You can also tap on the tank with your knuckles to hear if it has been cracked.
Similar Threads: Leaking Toto
Toilet Forum discussions Toto leaking what are these 2 rubber things disentegrating Dec 7, 2015
Toilet Forum discussions Toto Aquia 2 piece toilet leaking around base Dec 2, 2015
Toilet Forum discussions leaking new TOTO C744E toilet...help please. Nov 13, 2014
Toilet Forum discussions leaking toto unifit Aug 28, 2014
Toilet Forum discussions Toto Fill Valve Leaking Mar 22, 2014
