Leaking Mansfield 700 series sillcock
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pmoline, Oct 19, 2005.
  1. pmoline
    pmoline New Member
    Oct 19, 2005
    I have a 10 year old house and with a Mansfield 700 frost proof sillcock. When the water is ON, it leaks behind the handle, between the threads where the handle part of the valve screws in. Is there a repair kit for this valve? I can only seem to find one for the 500 series valves.
    Thanks for your help.
  2. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    Do you maybe need to tighten the packing nut that is on the end of the valve, between the handle and valve body? I like to have the water running a bit when I do this kind of tightening, just to take the pressure off the whole thing... I would think you would need replacement parts if it was leaking while the hose bibb is shut off.
Similar Threads: Leaking Mansfield
Plumbing Forum, Professional & DIY Advice Mansfield Anti-Siphon Wall Hydrant Leaking in Wall Mar 19, 2015
Plumbing Forum, Professional & DIY Advice Mansfield Anti-freeze Hose Bib - leaking again after winter May 24, 2013
Plumbing Forum, Professional & DIY Advice Mansfield 300 series Silcock leaking Jul 30, 2009
Plumbing Forum, Professional & DIY Advice Leaking Mansfield frost-free faucet Aug 7, 2006
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
