leaking joint?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bsperr, Jan 6, 2009.
  1. bsperr
    bsperr Member
    Apr 23, 2008
    Athens, GA
    I recently soldered in a tee to my 3/4 copper line to install an expansion tank to go along with a PRV. The joint looks filled, but there is not a bead of solder along the outside of the joint. I've been checking periodically for leaks, and every couple days I see a minute trace of water at the bottom of the joint. It's not beading or dripping, and I can barely tell it's there until I wipe it away with the tip of my fingernail. I've soldered bad joints before, and those leaks were VERY apparent. Does this sound like a leak or could it just be condensation (the rest of the pipes are pretty sweaty)? I just wanted to run it by you guys before I redid it. Thanks.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I suspect it is leaking. There must be something that makes you think it's a leak and not condensation, and I doubt that any reassurance to the contrary wouldn't set your mind at ease.:D I'm sure you know that you can not just add solder to the joint now because water has been present.
  4. bsperr
    bsperr Member
    Apr 23, 2008
    Athens, GA
    I thought it must be a leak but was a bit reluctant to cut it out before I got a little confirmation. Hopefully the next one will stick. Thanks Gary.
  5. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    I don't know where you live, but sweaty pipes are not good and lead to mold. Run a dehumidifier and see if the joint stays dry before you rip everything apart.
Similar Threads: leaking joint
Plumbing Forum, Professional & DIY Advice Advise on how to repair leaking copper sweat joint Sep 5, 2014
Plumbing Forum, Professional & DIY Advice tiny leaking crimp joint at toilet stop Sep 26, 2013
Plumbing Forum, Professional & DIY Advice repair leaking 3" PVC joint on vent top of sani tee Sep 25, 2012
Plumbing Forum, Professional & DIY Advice Slip joint on shower drain keeps leaking! Help! Jul 14, 2011
Plumbing Forum, Professional & DIY Advice Leaking p-trap joint and can’t unscrew nut Oct 1, 2010
