Leaking in-wall lav faucet valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by oddjob, Feb 22, 2010.
  1. oddjob
    oddjob New Member
    Feb 22, 2010
    Bellingham WA
    I bought a single handle wall mounted faucet for a new bathroom addition. The inlets on the mixer are female. I hooked them up to pex tubing with NPT 1/2" male threaded to 1/2" pex crimp fittings. The threads were treated with pipe dope (Rector Seal #5).
    The system is now leaking from the threaded connections. I think the male fittings may be bottoming out in the mixer body threads before establishing a seal.
    Am I using the wrong kind of fittings?
    Thanks for any input.
  2. Terry
    Aug 17, 2004
    Can you post an instruction sheet or picture?
    If they are tapered threads, then the pipe dope would be fine.
    If they are straight cut threads, they may use a flat rubber washer in between.
    But I'm only guessing without a picture.
  4. oddjob
    oddjob New Member
    Feb 22, 2010
    Bellingham WA
    The item came without instructions (risks of ordering from online discounters) and the specs from the manufacturer's web site don't say what standard the threads are.
    I'll try the washers to see if that seals things up.
    Is it acceptable practice to use rubber washers behind the wall where there won't be maintenance access?
  5. Terry
    Aug 17, 2004
    It's easy enough to tell if the threads are tapered by looking.
    If they are tapered, then you can't use a rubber washer.
    You might just need to tighten things up.
  6. jadnashua
    If they came with washers, then the threads are very likely not NPT (tapered) and the seal is created by the washer, not in the threads and pipe dope (or tape). You'd need a different connector.
  7. hj
    The valve WILL have tapered pipe threads. Any "odd" thread will be the PEX adapters, although even they should have the correct threads. You probably did not tighten them properly. Did you follow someone's directions to tighten them hand tight and then an additional turn? If so, that is your problem. You cannot tighten threads to a formula.
  8. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    If you bottomed out the threads then you either over tightened them or they are not tapered threads. I have run into that on european faucets. If you can hand tighten them all the way in then the threads are not tapered. I use loctite in that situation and it works well.
Similar Threads: Leaking in-wall
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Monday at 12:06 PM
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Monday at 10:12 AM
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Leaking Connection - Help Please! Feb 1, 2017
Plumbing Forum, Professional & DIY Advice water leaking shower room condominium Jan 22, 2017
