leaking heat system
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by homey6660, Jan 26, 2006.
  1. homey6660
    homey6660 New Member
    Mar 25, 2005
    Virginia
    I have a slow, steady leak coming from my heating system. Wondering if someone can identify what the particular pipe is and maybe suggest some solutions...(less than calling a plumber, though I will if necessary). THe pipe comes out of the unit and has a release valve. It branches off just prior to that point to an "overflow" (maybe) tank. This heats a radiator system (not steam). I have a picture of the particular area, but do not know how to post hear.
    Any advice is appreciated...
    Mike
  2. jadnashua
    This is on a hot water boiler? Do you have a pressure gauge on the system? What does it read? Depends on the system, but a reading around 10-15 pounds is common. The tank may be an expansion tank. If it is, my guess is that it may need to be replaced. Does it have a cap like on a tire on the bottom? If so, rap on the tank. Does it feel heavy and sound like it is full of water? Another symptom of a blown bladder in an expansion tank. Open the air valve momentarily on the bottom and see if water comes out. If it does, you've found the problem. They aren't much money, and are easy to install.
    A picture needs to be converted so it is fairly low resolution, and the size is only as big as it needs to be to show the affected area. When you post a message, scroll down below the initial box to the line thatsays manage attachments...click on your pic file, and there you are.
Similar Threads: leaking heat
Plumbing Forum, Professional & DIY Advice New water heater leaking Nov 26, 2015
Plumbing Forum, Professional & DIY Advice Water leaking from my water heater! Apr 30, 2015
Plumbing Forum, Professional & DIY Advice Water heater HotOut leaking today Dec 30, 2014
Plumbing Forum, Professional & DIY Advice Water heater pressure valve leaking. 5 year old heater. Home Cheapo Strikes again. Mar 25, 2013
Plumbing Forum, Professional & DIY Advice Leaking Hot Water Heater...fixable? or replace? Dec 28, 2011
