After opening the service stops and turning water on to the shower head a small amount of water drips came out between the water flow lever and the select lever.
Where would this leak be coming from ? Do I need a new valve?
Should I pull that valve from the rough in valve box and reinstalled adding more o-ring lubricant.
Would it be leaking at these o-rings?
I have attached a picture of the valve.
Any help much appreciated.
