Leaking G-Max or Power Gravity Fill Valve.
Discussion in 'Toilet Forum discussions' started by jt3, Jun 13, 2007.
  1. jadnashua
    Go to Lowes or a good hardware or plumbing supply house and pick up some cap replacements at about $2 each. If you're lucky, you can just clean the filter, but it's more likely the seal in the cap is worn. This assumes you have the Korky valve made for Toto (it doesn't have a big plastic screw on the top). No tools, and it should be as good as new for another 6-years or so (it all depends on your local water).
  2. srucker
    srucker New Member
    Oct 16, 2011
    Iowa
    Drip from the refill tube -- help needed
    I have Toto Drake toilets in our home -- they are about a year-and-a-half old. Recently two of them have had drips. Water is dripping out of the refill tube into the overflow pipe at a pace of approximately one drip per second. It doesn't happen all of the time (sometimes it will stop after being flushed) and I can stop the drip (at least temporarily) by pushing down on the filler float. Any suggestions would be appreciated. Thanks in advance!
  3. jadnashua
    Assuming you have the Korky version of the valve made for Toto, the seal is an easily replaceable part which costs about $2. Takes about 30-seconds to do, maybe longer the first time you do it.
  4. Sami
    Sami New Member
    Nov 1, 2011
    Vancouver, BC
    Toilet tank fills in intermittent spurts.
    I have a Power Gravity Installation which worked perfectly until the toilet was lifted and resinstalled when the floor was retiled a couple of weeks ago. Now the tank fills in short intermittent spurts. It is a Toto 6.0Lpf and takes about 10 to 11 spurts of water to fill the tank to about a third of the way up. Previously the tank would fill very quickly without stopping. Now the pump starts/stops/starts/stops until the water is up to the proper level. I have tried wiggling the pump in the tank but it makes no difference. If I use my hand to put a little pressure on the top of the pump it will work properly but once I take my hand away and reflush the intermittent filling is back. I'm not a plumber and not particularly mechanical but would like to try fixing myself since it just feels like something needs to be tweaked.
  5. jadnashua
    Inside of the flush valve there's a float. There could be some crud in there that is inhibiting the movement of the float. Also, there could be some crud in the seal, which is easily replaceable for a few dollars (available at Lowes and many hardware stores).
  6. orion24
    orion24 New Member
    Dec 29, 2011
    Virginia
    Drake Toilet Dripping into Tube
    My 5 year old drake toilet is dripping from from the black tube (from the fill valve) down into the tube connected to the flapper assembly. The water level is just up to the level of the tube after refilling. Is there an adjustment or do I need a new fill valve?
    Many thanks and Happy New Year.
    -orion24
  7. jimbo
    jimbo Plumber
    The fact that the water level is at the top of the overflow usually means that the fill valve is failing to turn off completely. Assuming it used to fill correctly, there is no adjustment, but the seal on that fill valve is easily replaced.
    [​IMG]
  8. cookn
    cookn New Member
    Mar 19, 2012
    Arizona
    Toto fill valve repair
    I have a Toto Carlyle (circa 2001) with the Gmax fill valve, that is failing. Will a Korky replacement cap work on the Toto version of the fill valve? I can't seem to find a Toto branded replacement, just a new fill valve (white screw style) that doesn't seem to be favored on these forums.
  9. Jim98311
    Jim98311 New Member
    Mar 19, 2012
    Bremerton, WA
    Same Question, different model
    I have an Ultramax with the TSU18A fill valve, which is no longer fully filling the bowl. We have some sediment in our water and I suspect some debris is in the valve. Is there any way to take the valve apart or clean it out? The tank fills fine, it's just the bowl that is the issue.
    Or does this call for a complete fill valve replacement? And if so, is the Fluidmaster 400ARHR a good replacement?
  10. Terry
    Aug 17, 2004
    I've used the Korky MaxPerformance valve on the TOTO bowls. It has an adjustable bowl fill that the TOTO needs.
    You can also use the Korky 528T
    [​IMG]
  11. jadnashua
    Assuming you have the Korky fill valve on your Toto, yes, the Korky replacement cap works and would be my first attempt rather than replacing the whole thing. While the one they make for Toto says Toto on it rather than Korky, they are shaped the same and take the same seal. Once you figure out how, it takes about a minute. While you've got it apart, check the screen and clean it if needed.
  12. feeth
    feeth New Member
    Mar 22, 2012
    GA
    So if my toto looks like this on the inside (tsu25a), see the attached files. I can use what Terry has listed below?
    I bought one of the $2.50 caps from Lowes and it appears they wont work.
    TIA!
  13. jadnashua
    Toto uses a couple of different fill valves, and the one you have is not made for them by Korky...sorry. As I understand it, that one is not repairable, and if it leaks, must be replaced. You do want one either made for Toto or one that is adjustable so that you don't waste water and get a good flush. Those made for Toto balance the bowl and tank refill so both just fill when the tank shuts off flow. Otherwise, you'll either end up with dumping excess bowl water down the drain, or not having enough water there so there's a lousy flush. Korky does make a generic adjustable valve that will work with any model and may be quicker to find than the custom one for Toto. That one has a little valve you adjust to balance the flow so both the tank and the bowl fill up at the same time...should only take a couple of minutes longer than a straight replacement to get it right after a couple of test flushes. I think there's a video on their website.
  14. feeth
    feeth New Member
    Mar 22, 2012
    GA
    Thank you Jim! I installed the above pictured korky valve and everything is all well.
Similar Threads: Leaking G-Max
Toilet Forum discussions Toilet Ring Leaking in Rental House Jan 3, 2017
Toilet Forum discussions Flushmate external regulator leaking Nov 18, 2016
Toilet Forum discussions Drake with a leaking flapper Nov 9, 2016
Toilet Forum discussions New Korky 528 Fill Valve looks like its leaking...bubbling Nov 9, 2016
Toilet Forum discussions Leaking toilet - with new flapper and flush valve Sep 14, 2016
