Leaking Foundation by Main Water Shut Off
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by GerryAsh, Feb 24, 2007.
  1. GerryAsh
    GerryAsh New Member
    Feb 24, 2007
    TV Guy
    Vancouver Island, BC, Canada
    I'm over my head... can somebody shed some light.
    My main water supply comes in through my basement foundation wall.
    It sits about 2 feet below grade. From time to time over the past 18 years there has been a water drop or 2 that has trickeled down the foundation wall at the hole where the water supply pipe comes into the house.
    This winter there is way more water. Now I have a minor stream when the rains come.
    Do I caulk the crap out of it, do I replace the old pipe, how do you waterproof such a thing? Or is this the job for a real plumber?
    :confused:
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The only way I've had success in sealing this type of leak is with hydraulic cement. You buy it in quart size cans. This will require that you open some space around the pipe as deeply as possible, making sure to get all of the loose pieces out. You mix a small amount at a time and immediately pack it into the space. It will work even with water coming in, in fact it needs some moisture to work properly. It sets up quickly, so you will need to work fast and mix a new batch if your supply sets up before you use it. If the pipe needs replacing, obviously this is the time to do that. When I had my water supply line replaced about 15 years ago, the plumbers used some kind of caulk, but it did not seal very well. I cleaned their caulk out and used the hydraulic cement. It's never even shown any moisture even though there is sometimes water stand outside. Be sure to follow the directions on the can of cement and use heavy rubber gloves, this stuff is loaded with lime, and it will burn your hands without proper protection.
  4. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    Make sure down leaders from gutters [if You have them] are tite lined away from found. Chances found. drainage was not done properly.
    Give the Hyd. cement a try, but the cause needs to be addressed.
  5. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    I agree with both Gary and Tool. The hydraulic cement (quickcrete, sakrete, water plug, et al) should seal up the leak, but you have to address why there's water around your foundation in the first place. The cement will put a bandaid on the hemhorrage, but eventually that water WILL find a way to get in due to the tremendous amount of hydraulic pressure against your foundation walls. Check your downspouts, the grade of the surrounding soil at the foundation....anything at all that could impede waterflow away from the house.
    Cheers!
  6. Cass
    Cass Plumber
    Nov 12, 2005
    If for some reason that doesn't work...which it should.... you may have to seal the foundation on the outside where the pipe enters it.
    Where I am all water services have to be inspected and one thing they check for is to be sure the foundation is sealed on the outside not just inside.
    I would also wait...if you can...until the water stops flowing to open and seal the hole.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    I don't want to start a running battle here, but hydraulic cement will stop active leaks permanently. I won't dispute the idea having good drainage away from the house is desirable, but hydraulic cement is not a band aid repair. This URL will take you to the Water Plug site. http://www.vexcon.com/support_docs/RP210CERTI-VEXWATERPLUG-DS.pdf
  8. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    Not to continue a running battle, but if you stop the bleeding in the arm and the leg starts next, you havent solved the underlying problem. Sure the hydraulic cement will stop the leak THERE, but what about the next weakest spot? Bottom line is there shouldnt be that much hydraulic pressure on the foundation to begin with which is THE problem. The leak around the pipe is a symptom, not the disease.
  9. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    Here in the bay area [S F ] the Geo Tex rule
    Drainage ,compaction ,detail on down spout water disposal ,are all documented
    By a soils engs. We get a good education. The situation on this thread is a failure. Someone didn't know,or care ,or both! WE do a lot of this work.
    Also the we compact the upper soil and pitch to drain. WE never went this route back East.It all cost money!
Similar Threads: Leaking Foundation
Plumbing Forum, Professional & DIY Advice Water leaking into foundation around water line Jun 1, 2013
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Leaking Connection - Help Please! Feb 1, 2017
