Leaking Drain Valve
Discussion in 'Water Heater Forum, Tanks' started by SAS, May 12, 2011.
  1. SAS
    SAS Member
    Dec 18, 2004
    I recently flushed my hot water heater and now I have a very slow leak (a few drops per day) from the spigot. Can I just put a cap on it, or do I have to replace the valve?
  2. jadnashua
    A cap will likely work, but if it is a cheap plastic valve, probably a good idea to change it. A full-port ball valve will flush better, and should easily last the life of the tank (and probably the next one, too).
  4. SAS
    SAS Member
    Dec 18, 2004
    Thanks for the advice. It's not a plastic valve, but it's not a brass one either. It's a flimsy aluminum valve. I was out last night at Walmart and picked up this metal ball valve intended for a garden hose for $3. So far so good. If it works, at least I won't waste 40 gallons of hot water.
  5. jadnashua
    If you turn the supply valve off and don't open any faucets, you can often just unscrew the old valve without losing much water at all. Think finger over the end of a straw. If no air can get in, no water can come out (or at least much unless something's leaking). But, that will work, too.
  6. SAS
    SAS Member
    Dec 18, 2004
    Good point. If this doesn't work (although for now it seems OK), I'll try shutting off the supply valve and opening the drain valve. If it doesn't leak much, I could change it without having to drain the tank.
  7. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    You probably didn't flush the tank as well as you think you did, since a conventional drain valve won't let larger particles through (as you have found out by the leak).
    Just bite the bullet and change over to a full-port ball valve like Jim says.
Similar Threads: Leaking Drain
Water Heater Forum, Tanks water heater is leaking out of drain pipe into yard Feb 14, 2014
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Sounds like pop off valve leaking.... Dec 8, 2016
Water Heater Forum, Tanks Leaking stainless braided water heater hose. Dec 5, 2016
Water Heater Forum, Tanks New T&P valves on water heater leaking, pressure driven from 65 to 165psi Aug 29, 2016
