Leaking drain (pop-up) assembly
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by slb, May 19, 2006.
  1. slb
    slb New Member
    Jun 17, 2005
    San Francisco North Bay
    I installed a new drain/pop-up assembly in a new bathroom sink and I can't get it to stop leaking. It seems to be leaking between the Mack washer and threaded section of the pop-up body. I have tried tightening the locknut in half-turn increments to no avail. Is it possible that I have over tightened it causing a distortion of the Mack washer and the leak? I didn't have this problem the two previous times that I installed a similar assembly.
    -Steve
  2. Terry
    Aug 17, 2004
    Drop the washer and nut down a bit, and push some plumbers putty into the threads. Just a little bit. You don't want any putty on the rubber washer, just in the threads.
    Without the putty, water will follow the threads down, past the rubber seal.
  4. slb
    slb New Member
    Jun 17, 2005
    Thanks Terry!
    I read the instructions, and they do say something about putting plumber's putty on the threads, but they are not very clear. I thought they were referring to the threads where the tail-piece attaches, not the threads under the washer.
    Regards,
    Steve
  5. Terry
    Aug 17, 2004
    I don't think what I posted will be found on any instructions.
    You asked why it leaked, and it's a common question.
    It's the answer that any plumber that installs faucets would be able to tell you.
    I have no idea why the people that write the instructions, never have to install the things and run water through them.
    To us plumbers, it's a no brainer.
    At least after we've fixed a few that way.
Similar Threads: Leaking drain
Plumbing Forum, Professional & DIY Advice Kitchen Sink Drain Basket keeps leaking? Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Leaking Sink Drain - Easy Fix? Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Drain Pipe is leaking outside. May be due to garden window installation 2mos ago. Need advice. Jan 28, 2016
Plumbing Forum, Professional & DIY Advice kitchen drain leaking at basement floor Aug 1, 2015
