Leaking Drain on Fibreglass Shower
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by deuce1974, Oct 26, 2008.
  1. deuce1974
    deuce1974 New Member
    Apr 4, 2007
    I have a new Fibreglass shower with the drain leaking. I think what happened is that the drain is hooked up with a rigid construction and any play in the shower pan caused the connection to break and of course is now leaking. I have cut a hole in my ceiling for the second time in a few months and wifey is getting pretty upset!! What is the best way to hook up these drains so there can be some play in the drain, would a rubber coupling work ? Please, any help would be appreciated
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    There should not be any "play" in the drainage piping. If the shower or tub base is deflecting enough to break the pipe you need to firm up under the tub. We usually do this with mortar. I've heard of guys using spray foam also.
  4. deuce1974
    Apr 4, 2007
    its one of those corner shower stalls that sits on legs that are adjustable, I am not sure if it would be possible for me to do it with mortar, its quite heavy, thanks for your response,
  5. deuce1974
    Apr 4, 2007
    Also I just looked at the shower drain again, the drain attached to the shower is white, so i am assuming pvc and the drain lines in the house are abs, could that have been the cause I wonder??
  6. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Why yes, yes it could. There is NO glue that will bond PVC and ABS. In fact, it is against the code to glue abs and pvc. I would change the shower drain to abs.
Similar Threads: Leaking Drain
Plumbing Forum, Professional & DIY Advice Kitchen Sink Drain Basket keeps leaking? Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Leaking Sink Drain - Easy Fix? Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Drain Pipe is leaking outside. May be due to garden window installation 2mos ago. Need advice. Jan 28, 2016
Plumbing Forum, Professional & DIY Advice kitchen drain leaking at basement floor Aug 1, 2015
