leaking compression fittings on supply valves
emptyb
This morning I discovered, unfortunately not until considerable water had collected, that the fitting downstream of the push-pull type supply valves to my dishwasher and sink hot water. Constant little dripping from this crimp, compression-type fitting, integral to the supply tubing. (Sorry, I don't know the correct terms.)
How do I fix this? Can I simply squeeze harder on these fittings? Do I have to buy new valves? (How are these attached to the copper supply lines?)
Many thanks in advance.
- Mark
