Leaking bath faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Southern Man, Nov 12, 2008.
  1. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    This one's got me stumped.
    This is the last of the Moen bath faucets in the house that I have occupied for over 11 years. I've had to replace all of them except this one. It's in a basement 1/2 bath and drains to a grinder pump that only serves that bathroom, pumping up to the public sewer.
    The pump float was hanging up so I shook the vent pipe to cycle it, then ran cold water from the faucet for 2 hours to clean out the sump, checking on it about every 15 minutes. I could also hear the pump cycling as normal during this time. On my last check there was water on the floor so I shut off the faucet, cleaned up the water (the vanity floor was soaked). I found the leak coming from the hole in the vanity top, down the stop operator rod.
    The leak stops when I turn off the faucet, and runs 2 or 3 drops per second when I turn on the hot or cold water.
    Where could the leak possibly be coming from?
  2. hj
    leak
    The most common place is that aerator is sending water back inside that sheet metal cover plate,and then it leaks through the center hole under the faucet.
  4. Southern Man
    Jun 27, 2008
    North Carolina
    Bingo- that was it! I cleaned out the aerator, checked the gasket (which was fine) and had to tighten it in with pump pliers to get the leak to stop, but it did. Thanks!
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Good thing he's overseeing you HJ!:D
  6. Southern Man
    Jun 27, 2008
    North Carolina
    Unlike certain people who think they know everything, yet obviously don't, I continue to learn every day. I've learned as much from guys with dirty fingernails as from academic types. :)
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Ah Grasshopper just when we thought you were impossible to teach, you contradict yourself....
  8. Southern Man
    Jun 27, 2008
    North Carolina
    The Southern Man is not afraid to learn. :)
  9. Redwood
    Dec 15, 2007
    Service Plumber
    A remarkable transition has occurred!:eek:
  10. Southern Man
    Jun 27, 2008
    North Carolina
    The Southern Man has been remarkably consistent. :)
  11. Redwood
    Dec 15, 2007
    Service Plumber
    Until now!
    [​IMG]
  12. Southern Man
    Jun 27, 2008
    North Carolina
  13. hj
    re the link
    And another thing to consider is that phone call routed through a satellite travels the same distance whether it is going next door or across the country, but you pay differently for the calls.
  14. Southern Man
    Jun 27, 2008
    North Carolina
    A friend of mine used to say that since you paid a much higher price per pound of propane to fill a 20# bottle than if you paid for a 300 gallon delivery, that it proved that the gas costs the propane company essentially nothing.
  15. redwoodvotesoften1
    redwoodvotesoften1 New Member
    Aug 27, 2008
    Wow Southern Man where did you git that picture...
    We all know you ain't got runnin water in your shack.
Similar Threads: Leaking bath
Plumbing Forum, Professional & DIY Advice Leaking plumbing to bathroom renovation Nov 21, 2016
Plumbing Forum, Professional & DIY Advice Water leaking from the bathtub near the faucet Jul 27, 2016
Plumbing Forum, Professional & DIY Advice Bathroom faucet pipes leaking. Feb 2, 2014
Plumbing Forum, Professional & DIY Advice Help needed - indentify bathtub fixture thats leaking Jul 6, 2013
Plumbing Forum, Professional & DIY Advice Bathroom sink, leaking at the pop-up drain connector. Jul 30, 2011
