leaking 1/4" compression fitting on angle stop
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by keeter, Jan 29, 2007.
  1. keeter
    keeter New Member
    Jan 29, 2007
    hello plumbers,
    i have an RO filter line 1/4" plastic tubing attached to an angle stop via compression fitting. This is the supply line to my RO filter. the compression fitting is leaking ( annoying seep). i have tried replacing the nut and compression sleeve (recut the line nice and square) but it dtill seeps. I do not think the problem is my angle stop which is pretty new. My question is should i use a plastic compression sleeve and tube insert with the metal angle stop? right now i have a brass sleeve and plastic tube insert. should i be using a brass tube insert in the plastic tube???
    hope this makes sense?????
    :confused: keeter
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Anytime you use plastic for water lines regarding your situation, ALWAYS use the plastic compression ferrule along with the brass stiffener.
    When you do this, thread that compression nut on and hand tighten it. THEN, turn the water on, it will leak. Take a wrench and turn it only until the leak stops.....then give it another 1/2 a turn and you're done.
    Overtightening can cause a leak as well as using a brass ferrule on plastic small tubing.
    If there is any bend to that tubing before it enters that compression fitting, it will slowly cut into that pipe and cause problems with a leak.
    That happens a great deal in my area with plumbers using pex toilet and faucet supplies and use the brass ferrules that came with the angle or straight stops; they cut the pipe eventually which is spelled danger in many ways.
  4. keeter
    keeter New Member
    Jan 29, 2007
    thanks UFF
    I'll give that a whirl. it makes perfect sense!:)
Similar Threads: leaking compression
Plumbing Forum, Professional & DIY Advice Leaking compression connector PEX hose under sink Jun 12, 2010
Plumbing Forum, Professional & DIY Advice External Frige Water Filter - compression fitting leaking Oct 15, 2008
Plumbing Forum, Professional & DIY Advice Compression shutoff leaking.. Help please! Jun 6, 2006
Plumbing Forum, Professional & DIY Advice Leaking Compression Union - SOS! Dec 4, 2005
Plumbing Forum, Professional & DIY Advice Leaking compression fitting Nov 11, 2005
