Leakign From Base pt.2
Discussion in 'Toilet Forum discussions' started by rtorrez, Apr 14, 2008.
  1. rtorrez
    rtorrez New Member
    Apr 9, 2008
    my toilet was checked for water leaking from the base of the toilet. A plumber friend of mine came to check it out and everythign was fine. Wax ring was still good and solid, no cracks in the flange, no hairline breaks on the toilet, and no leaking from the base. He flushed a few times and nothing. I told him that water would come from the bottom when preassure was applied to the toilet seat AND that it only happened sometimes. He could not see anything that would cause it. He went ahead and put a new war ring and suggested that I caulk the bottom of the toilet. He's worked with a lot of toilet problems and this is the only one that seems to be baffling him. I even showed him photos that I took. Anyone else had somethign similar to this wonderous mystery?
  2. bombjay
    bombjay New Member
    Mar 11, 2008
    Does the flange sit *on top* of the finished floor?
    is the floor a little spongy?
  4. rtorrez
    rtorrez New Member
    Apr 9, 2008
    no...its perfectly on there. The plumber said that it's the best job he has seen and perfectly fitted.
  5. Speedy7th
    Speedy7th New Member
    May 16, 2009
    Canada
    Hi rtorrez!
    I had a similar puzzling accumulation of water that I thought for a long time was due to a leak. It came and went just like yours, irregular. On a very light coloured tile, it was hard to see the full extent of water, but it was noticeable on the floor near the base of the seat/bowl. I naturally assumed it came from the wax ring area.
    I forget how I went about discovering its source, possibly laying out a bed of toilet paper strips. Turned out to be condensation on the back of the tank near the wall. But only during damp weather! In your part 1 you say the room didn't seem damp, but showers may make the room damp enough to not only cause condensation, but also to cause dripping. That, in combination with wet weather, or wet weather alone, can cause dripping: the humidity inside your house rises significantly during wet weather, enough to cause condensation on the tank. Note that water that comes into your house from underground pipes, is very cold. When this cold water fills the toilet tank in warm damp conditions, condensation is very likely. I suspect the restricted space behind the tank didn't allow evaporation to occur as easily as on the rest of the tank.
    In our case the drips fell in the darker floor area near the wall and, due to a slight slope in the floor, made its way towards the seat/bowl where we could then discover it.
    We now have an insulated American Standard 6 liter/1.6 gallon toilet; not because of the leak, but in order to save by using less water for each flush.
    There are trays on the market that fit under the tank to catch condensation drips. Or you could try hanging a towel behind the tank, provided it's in contact with the tank. Clamp the top edge of the towel under the tank cover to hold it in place.
    Good Luck! :)
    Speedy7th.
  6. hj
    leak
    I would bet on a leak between the tank and the bowl, or the tank's anchoring bolts. You may be tipping the tank when sitting on the bowl.
Similar Threads: Leakign Base
Toilet Forum discussions Need a short toilet base (front) Feb 13, 2017
Toilet Forum discussions New Basement Toilet Dec 4, 2016
Toilet Forum discussions Basement Toilet, no flange & looks like cast iron Jul 3, 2016
Toilet Forum discussions Basement toilet blows up! Apr 18, 2016
Toilet Forum discussions Would one be able to smell sewer gas from a bad wax ring if the base is caulked? Dec 16, 2015
