Leak under base of corner shower stall doors after cleaning, re-setting and caulking
Discussion in 'Shower & Bathtub Forum & Blog' started by SuburbBeth, Mar 30, 2013.
  1. SuburbBeth
    SuburbBeth New Member
    Mar 30, 2013
    Long Island, NY
    I have corner shower stall (two stable panels and two sliding panels which meet in outside corner). The track which is adhered to the shower pan is curved at the outside corner. Professional brought in to remove doors fully, clean, and recaulk entire shower and stall doors.
    The water from shower still leaks at this outside corner (where doors meet). The leak slowly streams between shower pan and the 'set' aluminum base track (which was re-caulked inside and outside). It is a slow 'pool' which leaks out and onto tile floor.
    Is there a solution other than purchase new set of shower stall doors? Is there any solution?
  2. jadnashua
    Is the entire pan set level? It sounds like it is not. There should not be any pooling, as the top of the curb where the door is attached should be sloped towards the drain. This won't be true if the pan is not set on a level surface, or it is not leveled when installed.
Similar Threads: Leak under
Shower & Bathtub Forum & Blog Old Leak Under Tub, Mold Issues Jun 19, 2013
Shower & Bathtub Forum & Blog Bathtub leaking under house Oct 15, 2009
Shower & Bathtub Forum & Blog Please help, my tub is leaking under my house Sep 14, 2007
Shower & Bathtub Forum & Blog Leak under side of old tub - Aug 23, 2007
Shower & Bathtub Forum & Blog so here another video of my leak from under the tub with wall removed May 15, 2007
