Leak proofing conrete utility room
Discussion in 'Remodel Forum & Blog' started by brador, Jan 9, 2008.
  1. brador
    brador New Member
    Jun 12, 2007
    New York
    My utility room, on the lower level, has two water heaters and a water pressure tank. The slab on one side of the room slopes slightly AWAY from the sump drain. I don't want to take out the appliances to correct the slab, but would prefer to simply create a two- or three-inch perimeter "lip" which would create a small pool and compensate for the incorrect slope. BTW, the basement is finished, so this lip idea would also protect the adjoining rooms from run-off. Any suggestions on a product? Something by Kwikrete, perhaps? Thanks!
  2. prashster
    prashster New Member
    Dec 7, 2005
    Might be easier to raise the appliances and put them in drain pans. Those pans cld be plumbed easily to the sump.
Similar Threads: Leak proofing
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog Chimney ? leak Nov 30, 2014
Remodel Forum & Blog Remodeling Bathroom...Leak Apr 10, 2013
Remodel Forum & Blog pocket doors and air leakage? Feb 1, 2013
Remodel Forum & Blog Pre slope and water leak test Mar 5, 2012
