leak in hot water tank after power outage
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by alleycat, Dec 15, 2008.
  1. alleycat
    alleycat New Member
    Oct 29, 2004
    Illinois
    Greetings from the northeast's ice storm
    After 75 hours, we finally got power back this morning. As soon as the burner kicked on the hot water tank started to leak from the cap at the top of the tank.
    Husband took off the cap and tightened up the screws and the leak slowed to a drip. He called a plumber who said it was not unusual to have a leak after so long without power, and it has now stopped, but I would say it was about a quart of water that leaked out before it stopped.
    Does this sound normal to you?
    Thanks for any input.
  2. hj
    leak
    I suppose by "cap" you mean the element. It is NOT common for it to happen, but if it was loose, it could have contracted when the water cooled and started to leak.
  4. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Isn't she referring to a gas WH?
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Maybe an indirect or oil fired too.
    Can you post a pic of where the water came from?
  6. alleycat
    alleycat New Member
    Oct 29, 2004
    Illinois
    Here's a picture. Water was leaking from the base of the small disk on the top of the tank. It is oil fired.
  7. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I don't know if that sort of leak is "normal" but it was an easy enough fix. :)
  8. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Never seen that type of heater before.
    I've replaced oil-fired water heaters and they didn't look like that.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Yea, I'm thinking it might be an indirect unit.
    Can you give us another picture showing the whole unit from further back?
  10. Dunbar Plumbing
    Apr 18, 2005
    Yeah, should be a huge blower assembly at the bottom on the ones I've seen, but there was a 6" flue pipe on top. :eek:
    I've only seen one in my days as a plumber, and that doesn't hurt my feelings as they are rare at best, and very very expensive to purchase.
    The one I replaced was covered in oil residue.
  11. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    that is Scarey...
    that scares me just to look at one of those things.
    if it is not leaking, dont ask any questioins, cause
    it appears to be very old,
    just be happy that it stopped leaking,
    cause that would be pretty expensive to change out....
  12. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    It is indeed an indirect and leaks on that particular brand are more than common. The tank will probably not last more than a couple more years if that. They were big warranty issues.
  13. hj
    leak
    In that case, what, and where, was the plug he tightened?
  14. alleycat
    alleycat New Member
    Oct 29, 2004
    Illinois
    Here's more pictures. Maybe I was not describing the system correctly. We have oil heat/ hot water. The system is 4 years old. The leak came from the hot water tank (on the left in the first picture.) The third picture is the sticker on the tank. Water was dripping from the bottom of the bolts around the perimeter of the metal cap on the top of the tank (it's actually two metal disks with a gasket in between.) It was probably a quart or more of water that came out within a half hour or so of power being restored. Husband tightened the bolts and the water stopped. (And he broke one in the process but found a replacement bolt that fit.)
    The cap is pretty corroded. We have well water which is somewhat hard.
    Again, main question is whether it is correct that this can happen after a power outage and is nothing to be concerned about.
    Thank you all for any input. It's much appreciated.
  15. Redwood
    Dec 15, 2007
    Service Plumber
  16. alleycat
    alleycat New Member
    Oct 29, 2004
    Illinois
    Thanks for the reply Redwood - it will need replacing because of the corrosion and that is what is causing the water to seep out? The tank is only 4 years old. :mad:
Similar Threads: leak water
Plumbing Forum, Professional & DIY Advice water leaking shower room condominium Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Water Main inside has a slow leak Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Does homeowner insurance usually cover water leaking fix(e.g. repipe or reroute)? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Water leak inside wall Nov 4, 2016
