springville
I have a basement bathroom with a shower/tub. The other day I noticed that the baseboards in the bathroom were wet. I suspected that the plumbing was leaking so I cut a hole to check it out. It was completely dry. No leaks. The tub has a three piece surround. I think it might be acrylic or something. I removed the caulking around were the surround meets the tub and discovered that there is water coming from that space. I seeps out very slowly and accumulates in the tub lip. Could this be coming from and upstairs bathroom? I see no other signs of a leak (no damp walls. ceilings etc.). The wall on the other side of the area is concrete so I can't get in there to check it out. Also, I don't have easy access to the plumbing in the upstairs bathrooms to check if it is leaking. Thanks in advance for any suggestions
