Leak in 2nd floor toilet!
Discussion in 'Toilet Forum discussions' started by Grill Sergeant, Jul 4, 2012.
  1. Grill Sergeant
    Grill Sergeant New Member
    Jul 4, 2012
    Atlanta
    Hello.
    I installed a new toilet in the 2nd floor master bath on October 2011. About 3 weeks ago (June 2012), I noticed a leak coming through the ceiling on the 1st floor directly under the toilet.
    My first thought was to replace the wax ring, so I tried that and the leak persisted. The toilet is up against a wall, and the drain pipe runs about 8 feet and drops down the opposite wall. When I turn the water off under at the water line below the tank, the leak stops. This means it can't be a leak in the line right? Otherwise it would still be leaking unless I shut the main off?
    At this point should I start thinking about ripping up the tile and sub-floor?
    Thanks for any help!
    -GS
  2. hj
    At this point you should call a plumber and let him diagnose it BEFORE you go crazy and start tearing things apart. Unless water is leaking out of the tank, turning off the water should have NOTHING to do with stopping the leak, other than preventing you from flushing the toilet.
  4. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    Leave the water on clean up floor and all porcelain meticulously. Now lay down newspaper on floor behind toilet and flush a lot. Newspaper shows a drop of water best. Toilets are not suppose to touch wall! My guess, the tank to toilet is leaking.
    I two think You need a plumber.
  5. Terry
    Aug 17, 2004
    Many installs require two wax rings. Unless the flange is above the finished flooring, you will need more then one wax ring.
    Sometimes the flange is on the first floor, and then the secondary flooring is cut around the flange. It may be 5/8" underlayment or it may be backer board and tile. If that is the case, one wax ring wont do the job.
Similar Threads: Leak floor
Toilet Forum discussions Pressure flush toilet leaks at floor Sep 13, 2012
Toilet Forum discussions leaking through floor Sep 23, 2011
Toilet Forum discussions leaky toilet riser in concrete floor Aug 2, 2011
Toilet Forum discussions toto drake leaking from floor base Apr 17, 2011
Toilet Forum discussions Toto G Max - Leak between Bowl and Floor Mar 21, 2009
