leak from top of fill valve?
Discussion in 'Toilet Forum discussions' started by apac, Aug 12, 2010.
  1. apac
    apac New Member
    Aug 12, 2010
    athens ohio
    water is leaking from the top of that black thing. i highlighted in red the rod, right under which is where the water appears to be coming from. the toilet is flushing fine, but refilling takes 10minutes. wasnt like this before. it is also making a whistling type noise when refilling, but everything i read says that only happens with the old float ball design, and this toilet has a overflow valve
  2. jadnashua
    Fluidmaster sells a replacment washer that may fix this. Sounds like you may have some debris caught inside. A new gasket washer is cheap, and worth trying.
  4. apac
    apac New Member
    Aug 12, 2010
    athens ohio
    so should i just buy a replacement top thing of the fill valve? i dont know what a gasketwasher is. i took off the black top thing and when i made it fill with water, it sprayed everywhere. and i did the watercolor in the tank test, no leaks if that means anything
  5. jadnashua
    The gasket only costs a buck or so and is easy to replace. The instructions are on the card.
Similar Threads: leak fill
Toilet Forum discussions New Korky 528 Fill Valve looks like its leaking...bubbling Nov 9, 2016
Toilet Forum discussions Toilet Was Leaking, Now Not Filling...Help! Apr 12, 2015
Toilet Forum discussions Toto Fill Valve Leaking Mar 22, 2014
Toilet Forum discussions Toto Aquia Dual Toilet with leak at connection of supply line and fill valve Mar 13, 2014
Toilet Forum discussions Gerber 28-790 leaking from fill valve Dec 2, 2013
