Leak from replacement drain gasket
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Paddy Coughlin, Dec 29, 2004.
  1. Paddy Coughlin
    Paddy Coughlin New Member
    Dec 29, 2004
    I just replaced a bathroom faucet set on a Corian lav but could not stop the drain gasket from dripping. Assuming that I did not seat it uniformly, I installed a new gasket and paid close attention to getting it squarely seated. I am still getting drips.
    The replacement set is good stuff (Giagni) and I don't suspect a quality problem. Before screwing the sink flange onto the drain rim assembly, I cleaned the opening and caulked the underside of the flange with the recommended silicone caulk.
    The original installation is 20 years old. It looks like some water migrated from the countertop via the hot water faucet over time and discolored the area around the bottom of the sink opening. Is this a typical problem that might be causing the poor seal? Any and all tips on how to get this baby seated will be appreciated.
    Best regards,
    Paddy Coughlin
  2. breplum
    breplum Member
    Oct 2, 2004
    Plumbing and heating contractor
    San Francisco Bay Area
    Loosen the nut and flat metal washer so that you can pull down the rubber washer. Dry the fine threads and run a small silicone caulk bead where the washer will make contact. Then tighten back up.
  4. jimbo
    jimbo Plumber
    I usually use my thumb to fill the threads on the drain body where the heavy gasket will sit, with plumbers putty. Otherwise, even though the gasket seals perfectly well against the bottom of the sink, a drop of water travels down along the threads just in time to ruin your day!
Similar Threads: Leak replacement
Plumbing Forum, Professional & DIY Advice Delta RP46074 leak after replacement Dec 12, 2015
Plumbing Forum, Professional & DIY Advice 3 questions regarding installation of a replacement assembly to stop a Jacuzzi leak. Dec 12, 2013
Plumbing Forum, Professional & DIY Advice Moen Valve leaks after replacement Aug 31, 2013
Plumbing Forum, Professional & DIY Advice Disposal leak, replacement, potential can o worms Feb 25, 2013
Plumbing Forum, Professional & DIY Advice Kitchen Faucet Replacement...problems with leak and cold water valve won't shut off May 31, 2011
