Leak detection and well water shutoff system
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Lucky Don, Oct 25, 2013.
  1. Lucky Don
    Lucky Don New Member
    Oct 24, 2013
    Systems Designer of capital equipment in the semic
    Nashua NH
    Hi All,
    I am writing about a leak detection/well water shutoff system I have developed. I do not use a shutoff valve or any type of computer controls.
    I use "Old School" over sized parts for endurance and reliability. Today everything is complicated and built with poor quality. They are not reliable and when you need a system to work this is as "bullet proof" as it gets. I shut off the power to the well pump when a leak is detected by interrupting the power to the pump with an inline power relay (clapper type). It is a NC relay so no energy is used till required to open the circuit. The system is powered by the pump power so no other power is required. To install it you would place the control box between the well power switch and the pressure switch or the pump controller power line. There is a wired by cable water sensor that is located under the well tank or any water delivered appliance and will send a signal to the control box when water is detected. There actually can be up to six sensors if desired with various cable lengths. It actually takes no longer that 20 minutes to install. The mounting of the control box will take longer that wiring the system. Thoughts??
    Thanks,
    Lucky Don
  2. Avid DIYer
    Avid DIYer New Member
    Nov 15, 2014
    New Jersey
    Hi Don, any way you could post a schematic and parts list, I have lost a tank and flooded the basement. I would not like that to happen again. I like "old school" they new how to build them to last.
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
Similar Threads: Leak detection
Plumbing Forum, Professional & DIY Advice Starting a business doing leak detection. Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Leak detection alarm Jul 16, 2011
Plumbing Forum, Professional & DIY Advice Leak Detection System Oct 26, 2010
Plumbing Forum, Professional & DIY Advice floodstopper leak detection system Aug 30, 2010
Plumbing Forum, Professional & DIY Advice Leak Detection Equipment Mar 18, 2009
