leak checking new bathtub drains
Discussion in 'Shower & Bathtub Forum & Blog' started by pedixon, Jan 22, 2012.
  1. pedixon
    pedixon New Member
    Jan 9, 2012
    Wa.
    Hi all. Am ready to leak check all my new drain lines, but not sure how to seal the bathtub over flow pipe for this leak test. Bathtub is already in place. I know I can get scew in plug for the tub drain itself.
  2. pedixon
    pedixon New Member
    Jan 9, 2012
    Wa.
    Just to clarify, this is new house. I am testing all drain lines.
  4. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    You don't see the over flow tested other than just over filling the tub so that the tubs overflow is working.
    Have you already flooded out the stacks and vents prior to this?
    Often the tub's drain and overflow happen in a second inspection.
    I have never seen a tub's overflow "Plugged". Never.
    JW
  6. pedixon
    pedixon New Member
    Jan 9, 2012
    Wa.
    No, I have not already tested drains and vents. Didnt know you did that prior to tub being hooked up. So how could I do it now
  7. Hackney plumbing
    Hackney plumbing Homeowner
    Jan 6, 2010
    Alabama
    I have tested waste and overflows along with the rest of the piping when the tub will not have an access panel or backs up to an outside wall.
    The thing is the manufacturer of your waste may not make a test kit for it. I'm not aware of a universal test kit so you may be stuck with disconnecting the waste and overflows and plugging the trap adapters
  8. pedixon
    pedixon New Member
    Jan 9, 2012
    Wa.
    Thanks for help. I have a watts so maybe I can get test kit.
Similar Threads: leak checking
Shower & Bathtub Forum & Blog Tub drain replacement & checking for leaks May 2, 2014
Shower & Bathtub Forum & Blog Price Pfister 3 handle tub faucet leak Monday at 4:24 PM
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Is this Grohe leaky tub spout diverter repairable?? Jan 2, 2017
