Leak - bad seal under sink
Discussion in 'Remodel Forum & Blog' started by tallensprings, Jul 21, 2008.
  1. tallensprings
    tallensprings New Member
    Oct 27, 2007
    I just installed two new vanity sinks in our master bath. The drain opening in the sinks look like they are a little uneven. When I tried to install the drains, the rubber gasket will not form a good seal with the sink. I bought a couple of replacement gaskets hoping they were a bit larger and would fix the problem. They did not. Any suggestions to make a tight seal?
    Tim in Colorado Springs
  2. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    If they are really off, you could return them...
    Other options
    1. use more gaskets at the same time
    2. Grind as needed
    3. two part Epoxy glue between the gasket and the sink. then lightly tighten until glue sets (24 hours) then tighten
    I would not suggest caulk since it is not water-tight unless completely cured (several weeks?)
    Edit: I am assuming you mean the underside since small leaks on the top side would not be a problem.
  4. tallensprings
    Oct 27, 2007
    Leaky seal
    Thanks for quick response Bill!
    The leak is indeed under the sink. It looks like the drain opening is slightly mishapen causing one side of the ruber gasket to jam up into the opening. I could not find a large enough gasket or nut to get around this. Unfortunately, the sinks are already adhered to the counter top.
    I will try to find a good epoxy and let you know what happens.
    Tim
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Hold on with the glue for a minute!:eek:
    Many times the actual leak is water coming down the threads under the rubber mack washer.
    Use Hercules Sta-Put Ultra Plumbers Putty (it is non-staining for all materials) under the pop -up flange, and apply teflon paste stread sealant such as Rectorseal on the threads under the rubber washer...
    This will probably cure your leak!
Similar Threads: Leak seal
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog Chimney ? leak Nov 30, 2014
Remodel Forum & Blog Remodeling Bathroom...Leak Apr 10, 2013
Remodel Forum & Blog pocket doors and air leakage? Feb 1, 2013
Remodel Forum & Blog Pre slope and water leak test Mar 5, 2012
