Leak at main stack
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by john6601, Aug 10, 2005.
  1. john6601
    john6601 New Member
    Aug 10, 2005
    I have water leaking down the main stack and have found that the source of the leak is the top (second) floor sink and shower. The toilet is not contributing to the leak. The stack is exposed in the basement, but is behind plaster walls in the kitchen and second floor bathroom. I’m not sure where to start breaking things out. Where does it make sense to make holes; the kitchen ceiling, kitchen wall, or bathroom floor? Any ideas? How would a professional plumber approach this problem?
  2. hj
    leak
    The shower being part of the leak makes it more difficult since that means the leak has to be in the ceiling/under the floor. It is probably a cracked fitting, so the best way is to open the ceiling in the lower level and try to access it from there.
  4. john6601
    john6601 New Member
    Aug 10, 2005
    However, leaking also occurs when the bathroom sink is on. This makes me think there is a problem at the main stack underneath where the shower and sink are connected, but above where the toilet is connected as the toilet does not contribute to the leak.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Leaak
    I think HJ is right...
  6. hj
    leak
    The shower and sink could connect at the same level as the toilet, or below it, but it would be very unusual for that connection to be above the toilet connection.
Similar Threads: Leak main
Plumbing Forum, Professional & DIY Advice Water Main inside has a slow leak Dec 14, 2016
Plumbing Forum, Professional & DIY Advice How to fix main water line leak issue-repipeing or rerouting pipes Oct 7, 2016
Plumbing Forum, Professional & DIY Advice Leaky spiral hose for main kitchen faucet pull-out line - fix without replacement? Sep 1, 2016
Plumbing Forum, Professional & DIY Advice Main valve leaking Jun 10, 2016
Plumbing Forum, Professional & DIY Advice Main Stack leaking May 26, 2016
