vivona
- Messages
- 26
- Reaction score
- 0
- Points
- 0
I replaced the flush valve in an old Crane toilet. The original beveled gasket between the flush valve and the hole in the bottom of the tank was a softer material that sealed well despite there being a small chip in the inside tank edge of the hole. The replacement flush valve uses a harder rubber beveled gasket that only contacts the edge of the tank hole, so water now leaks through the chipped area.
By the way, the original flush valve was not leaking, but since it was 29 years old I wanted to change it out while I was replacing the tank to bowl gasket which was leaking. Now I wish I had left the flush valve assembly alone.
So, what are my options?
I tried fitting a piece if rubber in the chipped area and installing the flush valve, but it still leaked.
If I could find a flush valve gasket that was of a softer material so it would compress down around the tank hole, it would also press into the chipped area and seal the way the original gasket did. Does such a gasket exist?
Would putting some GOOP or a similar glue in the chipped are and installing the flush valve work or would it eventually leak?
I am sure this problem has happened with other toilets. What is the proper way to fix it? I really don't want to replace the toilet if I can avoid it.
