Leak at ball valve nut
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by spta97, Dec 25, 2009.
  1. spta97
    spta97 Member
    Dec 1, 2009
    New York
    Hi all,
    I had to rerun the copper lines to my bathroom and was replacing the old bendable copper pipe so I had to do a lot of close-quarter fittings in the ceiling to get the pipe to go where I needed it to - it was a complete nightmare (I didn't know about the heatsink trick at the time).
    After several failed attempts (and a pretty bad solder burn) I got all 4 ball valves and multiple fittings soldered in a very tight area but I just noticed (a few months later) that one of the 3/4" ball valves has a slow drip from under the nut where the handle is attached.
    Is it possible that I got it too hot and melted something or is it just a matter of replacing a washer? I want to do everything in my power not to disturb the joints.
    Thanks..
  2. pipepusher
    pipepusher master plumber/gas fitter
    Dec 24, 2009
    master plumber/ gas fitter
    Nebraska
    Try to tighten the nut.
  4. spta97
    spta97 Member
    Dec 1, 2009
    New York
    Fixed!
    Well that seems to have done it! Thanks Pipepusher!!! :D
    I used blue handled ball valves for the bathroom and red handled ones for the kitchen so I could tell them apart. The red ones appear to be a solid piece whereas the blue ones have a packing nut. I also checked the other blue one and that one had some green discoloration so I tightened it as well. The one that was actually dripping took a quarter turn of the wrench before it gave resistance so it was defintely loose.
    I guess that you are meant to tighten these during installation so thanks again and Merry Christmas!
  5. pipepusher
    Dec 24, 2009
    Nebraska
    leaky ball valve
    You are welcome.Glad to help.
Similar Threads: Leak ball
Plumbing Forum, Professional & DIY Advice New Sharkbite 3/4" ball valve leaks Feb 14, 2016
Plumbing Forum, Professional & DIY Advice PVC Ball Valve Leak Dec 3, 2015
Plumbing Forum, Professional & DIY Advice Can i service stem which appears to be source of leak in watts ball valve? Feb 22, 2014
Plumbing Forum, Professional & DIY Advice Temporary fix for ball valve leaking since handle sheared off? Dec 14, 2013
Plumbing Forum, Professional & DIY Advice Stem Leak on Older Nibco Ball Valve Feb 9, 2013
