Leak around tank bolt on new toilet
Discussion in 'Toilet Forum discussions' started by Davebutch, Feb 19, 2010.
  1. Davebutch
    Davebutch New Member
    May 20, 2009
    Richmond, VA
    I just installed a new Toto Drake two-piece elongated toilet using the directions provided in a posting on this forum (excellent instructions, by the way). Anyway, there is a consistent seep around the bolt that holds the tank to the bowl on the left side. It drips a few drops per day. I have taken the tank off and lightly sanded the area inside the tank where the gasket for this bolt contacts the tank and reassembled. I tightened both bolts enough to get the three points of contact that Toto specifies, but I don't want to risk tightening so tight that I crack or break something. The seep and drips are still there. Any thoughts how I can stop the leak in this area? Otherwise, I am extremely pleased with the toilet.
  2. Tyman 2
    Tyman 2 Licensed Plumber
    Aug 10, 2008
    Licensed Plumbing Contractor
    Indiana U.S.A.
    Take the tank off.
    Tighten the bolts on the tank.
    Set tank on bowl.
    When you are tightening the tank to the bowl you must use a screw driver in the tank so that the bolt does not spin. They must not spin or move. I have tried this out on three Drake's I installed and found this was the issue for me, mainly because I used a rachet to install them without using a flat head screw driver in the tank.
    Hope this helps.
Similar Threads: Leak around
Toilet Forum discussions Toto Aquia 2 piece toilet leaking around base Dec 2, 2015
Toilet Forum discussions Can't stop leaking around flange Aug 7, 2014
Toilet Forum discussions Leak around base of new toilet install 2 weeks later. May 5, 2011
Toilet Forum discussions Leak around base after replacing wax ring and toilet! Oct 31, 2008
Toilet Forum discussions Help! Leak around toilet base Mar 18, 2006
