Lead sleeve - what does it do?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TedL, Jan 22, 2007.
  1. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    I found my basement toilet drain has a lead sleeve over the flange going into the cast iron. What purpose does it serve? To smooth the inside surface when a set screw mounted flange has been used??
    If I remove this sleeve to inspect the flange and replace the toilet mounting bolts, are replacements (or substitutes) still available?
  2. hj
    lead
    We would have to see a picture, because usually that lead "sleeve" is the actual drain pipe for the toilet.
  4. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
  5. hj
    pictures
    You were too close and/or used too high of a resolution for the pictures. They are huge and blurred.
  6. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Clicking on the link and resizing the Explorer window to about a quarter of the screen lets them show well.
Similar Threads: Lead sleeve
Plumbing Forum, Professional & DIY Advice Lead Bend Repair? Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Do drains leading into lift pump need vents and traps Jul 28, 2016
Plumbing Forum, Professional & DIY Advice Flint moves on lead problems, And how! Apr 1, 2016
Plumbing Forum, Professional & DIY Advice How do I install a toilet to this?... Lead bend no flange Mar 20, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
