Lead Risers? Where's the Flange? Need Advice?
Discussion in 'Toilet Forum discussions' started by ssspargur, May 13, 2010.
  1. ssspargur
    ssspargur New Member
    May 13, 2010
    Illinois
    I've read a ton of other peoples posts on this subject and I hate to beat a dead horse, but.... Toilet was leaking so I took it off just thinking it might be a wax ring replacement. Well, what I found and the fact that I am planning on removing the old floor layers in the entire bathroom (re-floor) made me think I should get some additional advice. (Excuse me if I use the wrong terminology, my LIMITED knowledge is base only on what I've picked up on forums.
    So from bottom to top, what I found was a CI hub--lead pipe--lead riser--another lead riser--smooshed wax ring. No flange anywhere. From what I've read with lead risers, there should be a brass flange soldered to the riser.
    I'm planning on stripping the layers of my floor and laying some tile. So if I'm going to get dirty with this toilet, now's the time. I know I am going to have to replace some subfloor from the water damage. I guess what I'd like to know is my options. Any suggestions welcome and I appreciate your time and help. Thank you.
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    If it was me i would remove "all" that lead down to the tee and
    replace with ether a piece of 4" cast iron or sch. 40 pvc sewer pipe
    then you can install a proper flange,
    any thing with that lead will just be make do and always a source of leaks !
    If this looks more then you can handle i would at least get a professional plumber to
    replace the pipe then you can install whatever new flange you need after the flooring
    is complete !
  4. ssspargur
    May 13, 2010
    Illinois
    Materials
    Thanks a bunch. That was one idea I thought about. What would you usu, as far as material, at the junction between the CI and the PVC. Thanks again.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There is a "doughnut" that will make that transition. I think it is a Fernco product.
  6. ssspargur
    May 13, 2010
    Illinois
    Donut
    Copy that... Thanks... Now I'm trying to figure out the best way to remove the brass ferrule from the CI hub.
  7. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Its not hard to do just a PITA. Drill a lot of holes in the lead thats holding the brass in, then take a screwdriver or chisel and pry the lead out, once you get that done you will probably have to pry the oakum out also. To get a donut for your fitting check the letters on the side of the tee, should be a sv or a xh thats the way you have to buy them, those letters and the type plastic you are using, luck
  8. jadnashua
    Fernco makes those dognuts in 1/16" increments, since each foundry had its own idea of what size to make the CI hub. Get one too small, and it leaks, get one too big and it's a bear to get the pipe inserted (if you can at all)...so, measure it once you get the lead out and the interior brushed of any crud (old oakum, etc.).
Similar Threads: Lead Risers
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
Toilet Forum discussions Oatley Twist-N-Set into Lead Bend? Nov 12, 2015
Toilet Forum discussions Toilet flange - cast iron and broken lead closet flange Nov 8, 2015
Toilet Forum discussions Cast Iron / Lead Flange Condo - Repair / Replace Jul 22, 2015
Toilet Forum discussions Brass to Lead Flange Setup Jul 18, 2015
