Lead pipe sizes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rockycmt, Mar 13, 2009.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    What are the standard lead pipe diameters around the 4 inch mark? I ask cause I have 2 pipes. One I cut and put a 4" boot to convert to PVC. The other I did not do just yet cause it looks slightly smaller that the first. did a circumference test and it is definitely smaller that the first. Seems like 2 inch cir difference. Afraid the 4" boot will be too loose. house is from the 50's
    Thanks
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Putting a rubber coupling on lead is not a good idea.You need to cut back to the solid pipe then go from there.Is it C.I. or copper that the lead is connected to?
  4. hj
    lead
    Lead is not a good candidater for a compression joint because it CAN compress. Even the brass ferrule that the lead is soldered to is tapered so it should also be removed and the connection made differently.
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Forgot to mention the brass ferrule.Need to go back to the best section of pipe.
    Be it C.I. or copper.They where using DWV copper in the 50`s
  6. hj
    bend
    I doubt, and have never seen, a lead closet bend used with a copper DWV system.
Similar Threads: Lead pipe
Plumbing Forum, Professional & DIY Advice Replace lead drain pipe going into stack Sep 9, 2015
Plumbing Forum, Professional & DIY Advice Flange broke off from lead pipe at toilet -- how to replace? Aug 30, 2015
Plumbing Forum, Professional & DIY Advice Replace lead pipe with pvc question Jul 31, 2013
Plumbing Forum, Professional & DIY Advice Old Flexible Lead Pipe, HOW to attach to? Mar 7, 2013
Plumbing Forum, Professional & DIY Advice need to reattach roof drain leader to sealed standpipe "mystery drains" Feb 11, 2013
