Lead closet bend doesn't reach floor
Discussion in 'Toilet Forum discussions' started by Franklin1918, Sep 26, 2013.
  1. Franklin1918
    Franklin1918 New Member
    Sep 26, 2013
    NY
    Our home was built in 1918. The upstairs toilet has been leaking, and when I went to replace the wax ring I discovered that the lead bend (I'm assuming it's lead, anyway) does not even reach the top of the floor. It is pretty mangled, and there is a gap between the pipe and the underside of the wood floor. This has allowed gas to leak out. I think the water leak is due to the floor being uneven, so we have a couple issues to deal with. There was a metal flange screwed into the wood, which I removed. It was badly bent. The wood around the opening is damp, but does not appear to be rotted. Was hoping to DIY this inexpensively, but I think this is beyond my ability now. What would the repair entail? There is not access to the pipe from below.
    I'm attaching some pictures that hopefully show the situation better than I can describe it. It's tough to tell from the pictures, but the top of the lead pipe just reaches the bottom side of the floorboards, and in some spots it doesn't reach at all. It bends immediately, so there is not enough depth for an interior fitting (but from what I understand from reading other threads, that shouldn't be done with a lead pipe anyway).
    IMG00194-20130926-2038.jpg IMG00195-20130926-2038.jpg IMG00196-20130926-2038.jpg
  2. jadnashua
    You may not have much choice other than to cut open the ceiling below, or tear up the floor in that room to render a proper repair. If that pipe ever got clogged, guess what, it wouldn't only be gasses that could escape, but sewage all over the ceiling of the room below. Plus, if the wood stays damp long enough, it will rot it out and could attract carpenter ants and termites. You either need to replace the entire lead toilet bend, or cut it out and transition to plastic. If you get a new lead toilet bend, it would be long enough to come above the toilet flange and be bent over it so there'd be a continuous surface that the wax ring can seal to.
  4. Franklin1918
    Sep 26, 2013
    NY
    Thank you. Never even thought about what would happen if there was a clog--yikes!
    Is soldering a new portion onto the existing pipe out of the question? I'm having a plumber come to take a look hopefully today. I don't want to cut corners, but also don't want to go too crazy since I eventually want to gut the entire bathroom and redo the plumbing anyway (I don't think I have the money for that yet).
  5. Terry
    Aug 17, 2004
    Your bend looks pretty bad. I replace them when they get like that.
    [​IMG]
    I normally just pull the lead out of the cast iron tee, and use a 4x3 flush bush into a insert rubber pipe donut.
    [​IMG]
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If you do as Terry suggests, when you remodel the bathroom, it will be a simple matter to reposition the flange on top of the new floor.
  7. Franklin1918
    Sep 26, 2013
    NY
    Thank you--that looks like a good solution. Looks like we will just have to bite the bullet and pull up the floor.
    Now it seems like the hardest part of this project is going to be getting a plumber to show up!
Similar Threads: Lead closet
Toilet Forum discussions Toilet flange - cast iron and broken lead closet flange Nov 8, 2015
Toilet Forum discussions Need to Repair Lead Closet Flange but the Pipe is Crooked! Aug 21, 2013
Toilet Forum discussions New Closet Flange on lead elbow without solder Nov 27, 2009
Toilet Forum discussions Slanted vertical waste line leading to toilet/closet flange Jun 18, 2009
Toilet Forum discussions Removing Leaded Closet Flange Jun 23, 2006
