Ok, first thanks for all the advice in advance. This is a great forum.
So I started a partial demo on a 2nd floor 1930's bathroom. Tore out 3 layers of vinyl and 1x5x3/4 layer of T&G pine. I'm left with another layer of 1x5x3/4 T&G pine for a subfloor. My plan is in stall a new toilet, new vanity and new 1" hex tiles. Intial plan was to install 1/2" exterior ply and 1/4" cement board over the existing T&G pine until I came across this. Oh nothing is easy.
Underneath the vinyl surrounding the wast line is, 1"x18" slab of stone either slate or blue stone(I think). At the moment I cannot remove it, not sure if I even should, becuase the waste line I believe is a lead bend and it tapers out above the stone slab, there is a height difference b/w the stone and taper of about 1/2". Did I mention there is currently no flange, just a loose ring around the pipe for the lag bolts, at least there was a wax ring. Do I need to add a flange? I would think yes, if so what kind. Also, I'd like to remove the stone slab, so I can reduce the height of the overall floor. This would also mean cutting the pipe to achieve the desire floor height. My access under the floor is limited. Toilet is going be Toto Dartmouth.
If needed I can supply a picture, I'm not on location at the moment. I am the homeowner, money is limited becuase this house needs a descent amount work, though I'm doing most of it.
Thanks again.
Thanks again.
