Lavatory pop up drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pbr3232, Apr 24, 2009.
  1. pbr3232
    pbr3232 New Member
    Mar 16, 2009
    I have a lavatory pop up drain that is in sink that is siliconed to the counter. The pop up tail piece goes into a trap adapter that is glued onto a piece of pvc into a drum trap. The idea is I can't remove the trap or drop the trap adapter to give some slack to remove the drain assembly. I am jammed between the sink and the trap adapter. How would you remove the pop up drain assembly and put a new one in without having to lift the sink off.
    Thank You
    Peter
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Sawzall time!
    Or "tiny tim" or hacksaw or tubing cutter...
  4. pbr3232
    pbr3232 New Member
    Mar 16, 2009
    You can cut the old one. How about putting the new one in.
    Thanks
    Peter
  5. kingsotall
    Aug 17, 2008
    This is taking it a bit far but would work. Drill two hole through the pipe so you can stick a screwdriver in it and use it for torque. Obviously you have used pipe wrenches and channel locks to no avail, I assume.
  6. pbr3232
    pbr3232 New Member
    Mar 16, 2009
    Appreciate your response but I think we are talking two different thing. I was wondering how you replace a pop up drain assembly when you can't remove the trap because the trap and trap adaptor is glued and there is no slack and the lav is siliconed down. I could pop the lav up install the drain and silicone it back.
    Thanks
    Peter
  7. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I picture would be helpful.
  8. pbr3232
    pbr3232 New Member
    Mar 16, 2009
    Here is a photo I hope.............
  9. SewerRatz
    Nov 20, 2008
    Chicago, IL
    I can already hear what everyone else is going to say.
    It will be in the lines of cut out that drum trap, and replumb that drain line with a tee, atop of that tee put an AAV, and on the tee branch install a trap adapter and a p-trap.
  10. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    What city and state is this in.
  11. pbr3232
    pbr3232 New Member
    Mar 16, 2009
    It's in an area where drum traps are illegal. But it is existing so whether it a drum trap or an s trap it okay. I just want to change the pop up drain. If you are jammed you are jammed whether it be pvc or a galvanized drain pipe. I will just pop up the sink.
    Thanks
    Peter
  12. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  13. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
  14. SewerRatz
    Nov 20, 2008
    Chicago, IL
    I bet it was illegal before they allowed PVC and before they started to make PVC drum traps. Also most codes only allowed drum traps to be used with bathtubs.
    What MACPLUMB 777 said is true very easy to cut below the elbow and fernco it back in with a shielded fernco coupling.
    But its just as easy to repipe the PVC by cutting below the 90 glue in a sanitary tee a short pipe on the run with a trap adapter, and an AAV on the top of the Tee. See below image I stole from Redwood. I mean why keep it the way it is, when you can easily correct it and make it a whole lot better than what you have now. I normally do not recommend the use of AAV's I am in an area that requires proper vent piping.
    [​IMG]
  15. kingsotall
    Aug 17, 2008
    SewerRatz, is that really you¿ Suggesting AAV's¿ :eek:
    edit: Oh, ok.
  16. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Yea I decided to at that note... I rather see an AAV than what is there.
  17. kingsotall
    Aug 17, 2008
    btw, pbr3232, the most proper way to replumb your setup is with a loop vent.
    [​IMG]
  18. Redwood
    Dec 15, 2007
    Service Plumber
    No because those are only allowed on island sinks.
  19. Redwood
    Dec 15, 2007
    Service Plumber
    OMG tear my eyeballs out!:eek:
  20. Ian Gills
    Jul 24, 2007
    USA
    There is no way a Milwaukee 15 amp would get through that pipe.
    Still have not tried mine out yet...
  21. Cass
    Cass Plumber
    Nov 12, 2005
    Follow SewerRatz suggestion and it will make your plumbing system happy and your job easy...Redwood...Does CT allow AAVs...
Similar Threads: Lavatory drain
Plumbing Forum, Professional & DIY Advice Lavatory drain gasket not seating Sep 27, 2015
Plumbing Forum, Professional & DIY Advice Lavatory drain replacement - gasket? Mar 16, 2015
Plumbing Forum, Professional & DIY Advice Double lavatory not vented, gurgling, not draining well Dec 7, 2014
Plumbing Forum, Professional & DIY Advice lavatory drain leak below integral lav/counter at top rubber gasket Oct 15, 2013
Plumbing Forum, Professional & DIY Advice Lavatory push-up drain - need more travel Apr 14, 2013
