lavatory drain: need suggestions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by traff_ss, Jul 24, 2007.
  1. traff_ss
    traff_ss New Member
    May 13, 2007
    I recently replaced a rather large pedestal sink with a much smaller wall hung unit:
    [​IMG]
    With the new sink, the distance from the drain back to the wall was decreased so much that I couldn't install the p-trap in the normal fashion; instead I had to use the 2 45's and hang the p-trap off to one side. With all the additional slip-joints, the whole system is now rather fragile. So, I'm soliciting suggestions on a better way to solve this. One person has suggested I try to find a "compact p-trap" (one which does not take up as much horizontal space), but I have never seen one.
    I have about 6" or so to work with...
    I would appreciate any input...thanks in advance!
    tom
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    looks good as is. The most low cost option is to glue a reinforcement between the tile and the chrome (pipe). The tiles look good, btw.
    since you asked about alternatives, look into "bottle traps". They will make a straight line down and across. Decorative bottle traps, chrome plated brass, are available for just this purpose. It's supposed to be better-looking, a "visible " drain thing, that doesn't look much at all like utility plumbing. Some are chrome plated plastic. None are inexpensive.
    What you have is a P trap, better at draining than a bottle trap. No big difference in a hand rinse sink. Usually you can undo a bottle trap easily (with its slip joints) if you want to look inside the bottle part, clean it, and remove all those guests' diamond rings they dropped down there. Some have strainers where the pop-up lever gets screwed in on the side of the pipe just below the drain, so you'll be unscrewing something to remove hair and stuff on a regular basis anyway, at that spot. But, with your faucet in the corner, it may not be a good idea to get one with a lever pull pop up, or said another way, the pop up may only work if you press it down manually and lift it underneath; I'm not sure about that since I haven't done sinks with corner taps.
    David
  4. traff_ss
    traff_ss New Member
    May 13, 2007
    bottle trap = good suggestion
    Hey, thanks David, the bottle trap is something I haven't seen before, and is a good suggestion. Man, they are expensive, but I did find a few on ****...I think the wife will be happier about the way it looks too :)
    and thanks for the comment on the tile...!
    tom
  5. jadnashua
    As I understand it, bottle traps, while they work, are not code and are more susceptable to getting clogged with hair, etc. It may also be an issue if you need to get the install inspected, or if the house inspector picks up on it when selling.
  6. spetrucco
    spetrucco DIY Junior Member
    Jul 1, 2007
    Communications
    Southeast PA
    Wall Clamps
    Tom,
    I run a lot of emt conduit inside buildings and use pipe clamps offset via all-thread that thread into wall clamps. This would require drilling a couple more holes in your nice tile work but would not require you to change your piping configuration. They may come in crome to match your existing color to.
    Just an idea.
    -Shawn
  7. traff_ss
    traff_ss New Member
    May 13, 2007
    Thanks to everyone for the suggestions. Yea, I don't want to mess with something that isn't code since we will be selling the house in a couple years.
Similar Threads: lavatory drain
Plumbing Forum, Professional & DIY Advice Lavatory drain gasket not seating Sep 27, 2015
Plumbing Forum, Professional & DIY Advice Lavatory drain replacement - gasket? Mar 16, 2015
Plumbing Forum, Professional & DIY Advice Double lavatory not vented, gurgling, not draining well Dec 7, 2014
Plumbing Forum, Professional & DIY Advice lavatory drain leak below integral lav/counter at top rubber gasket Oct 15, 2013
Plumbing Forum, Professional & DIY Advice Lavatory push-up drain - need more travel Apr 14, 2013
