Mrramsey
Greetings. So I was installing a couple of new lavatory faucets for my in-laws. The first one went in perfectly which is what I like to see being that I am a carpenter and not a plumber. Now as best I can tell the circa 1980 cultured marble top was defective from the get go. When I seat the flange in the bowl the tail section clearly is not square to the bottom of basin where it is ground flat. It is off so much that when I tighten the drain gasket one side gets pushed into the hole on the bottom thus does not seal.
Any solutions to this outside of replacing the entire top? Is there an oversized gasket available?
