Lav drain: 1 1/2" with long thread
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jimathrc, Oct 20, 2012.
  1. jimathrc
    jimathrc New Member
    Oct 20, 2012
    Halifax, NS
    Hi,
    I'm trying to install a custom-made vessel sink on a concrete countertop. I had the sink made for a 1 1/2" drain (probably should have used 1 1/4" I've just learned). The countertop is 1 1/2" thick. I got a standard 1 1/2" pop-up drain, installed it and it leaked. I think the reason was the there is not enough thread sticking through the countertop to get everything together will the washer supplied.
    The sink and countertop are in place so I'm trying to find a 1 1/2" drain with a long thread (e.g. 4"). Does such a thing exist? If so, who makes something like that? I've looked on-line at Home Depot, Kohler, etc. with no luck. I will appreciate any pointers.
    thx,
    Jim
  2. hj
    Unless the sink does not have an overflow, so no water gets into the area below the drain's flange, you will never get it to stop leaking. If it does not have an overflow, then you do not really need any gaskets under the sink so what you have should work.
  4. jimathrc
    jimathrc New Member
    Oct 20, 2012
    Halifax, NS
    Hi,
    Found the source of the leak: a crack in the flange of the short waste pipe. See attached photo. (I should have seen that when I put it together!)
    I put it together with no washers and it's working fine.
    cheers,
    Jim
  5. hj
    What photo?
Similar Threads: drain long
Plumbing Forum, Professional & DIY Advice Sink drain question - long vs short 90 Oct 30, 2016
Plumbing Forum, Professional & DIY Advice My Weekend Adventure with Enzyme Drain Cleaner - Long Read Dec 6, 2015
Plumbing Forum, Professional & DIY Advice Long sweep san-t elbow for sink drain question Jan 26, 2015
Plumbing Forum, Professional & DIY Advice Where does the cleanout for long trap arm continuing into horizontal drain go? Dec 31, 2014
Plumbing Forum, Professional & DIY Advice Drain options when replacing an existing tub with a longer one (longer trap arm)? Mar 12, 2013
