Laundry Tub with No Visible Trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sbaitso, Jun 3, 2006.
  1. sbaitso
    sbaitso New Member
    Jan 4, 2006
    In my basement is a laundry tub (aka stationary tub) that the washing machine drains into. For some odd reason, it has no trap. There is simply a straight length of PVC drain pipe that was somehow fitted into another larger pice of PVC that goes under the slab. The house was built in the '20s, so it is an older home. Is there a chance that there is a trap under the slab? I have never smelled any sewer gas, and it otherwise functions fine. Is this fairly standard? or would I need to install a trap?
    I'll try and post some pics to illustrate.
    Thanks for any advice. I'm really learning alot from this forum.
  2. brownizs
    brownizs In the Trades
    Feb 9, 2006
    Springfield, IL
    It is possible, but you wouldn't know, unless started busting slab.
  4. sbaitso
    sbaitso New Member
    Jan 4, 2006
    some pics... if they provide any help. And after looking again, I don't think its PVC thats under the slab. Its so covered in stuff that its hard to tell.
  5. jimbo
    jimbo Plumber
    In the house where I grew up, they drained the laundry sink in the basement to a sump, and it pumped out into a separate drywell in the back yard. I presume this was to keep the laundry and ground water in the sump out of the septic.
  6. hj
    pipe
    They didn't even have PVC in the 20's. It is probably a clay tile pipe at the floor, but whether it has a trap or not can only be determined by being there and checking it.
  7. jadnashua
    If you can see standing water in the bottom of the pipe, it probably has a trap.
  8. Ron Coleman
    Ron Coleman New Member
    Feb 11, 2006
    Columbus, Ohio
    My guess is that the tub drains into an old floor drain and someone extended it with some pvc and cemented in the drain pipe. Probably to contain the frequent floods.
    The classic problem of water backing up when the washer pumps out is evident from the rusty legs on the tub frame. There is most likely a cast iron p-trap just under the surface.
    Ron
  9. sbaitso
    sbaitso New Member
    Jan 4, 2006
    I was wondering if it was something like that... though there is another floor drain about 6 or 7 feet from where this drain is. That drain is in a lowspot on the basement floor, while this one with the sink is not.
  10. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    go get a repair "s trap"
    if you are worried about it
    you should be able to go find an old style "S trap"
    and install it into that space you have to work with...
    Yes, I know that "s traps" are illegal for new construction
    but its fine for what you gotto work with
  11. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Alphabet soup
    Could you briefly explain the difference between S, J, P, etc., traps? Every trap I've ever seen looked pretty much like all the rest, but I never paid close attention.
    -mike
    (clearly, not an expert)
  12. prashster
    prashster New Member
    Dec 7, 2005
    Not sure what J Trap is. I thought it was just the 'wrong' name for a p trap.
    S trap has a vertical tail piece. S traps are 'illegal' anymore because they can cause trap siphoning. P trap has a longer horizontal tail piece that has a vent at or before the vertical transition.
    But yr right, they both look the same - between the fixture and the trap.
  13. hj
    trap
    A "J" trap is really the "J" bend for a "P" trap. Do not put an "S" trap on your sink until you verify that there is not actually one below the concrete, or you will have a sink tht might not drain at all.
  14. sbaitso
    sbaitso New Member
    Jan 4, 2006
    I guess I'll just have to move the sink and peer down the drain to see if there is any standing water. Chances are I would have smelled something foul if there was no trap, correct?
    My hope is to someday move the sink over a foot or two so it sits in a location that is easier to get to... but I'll obviously have to keep the drain at the same spot in the floor.
    Thanks for all your input.
  15. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    If a floor drain was near by, then its probably an old cleanout. Undo the drain and take a look with a flashlight for water.
    Jason
Similar Threads: Laundry Visible
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Laundry Room Renovation Plumbing Help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Updating laundry plumbing - vent and drain pipes Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Laundry tub/washer sanitary tee question Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Dealing with plumbing in a small laundry room Jan 12, 2017
