Laundry stack - can pipe size be reduced?
Discussion in 'Plumbing Code Questions' started by mikeygstl, Nov 18, 2012.
  1. mikeygstl
    mikeygstl New Member
    Apr 17, 2012
    Saint Louis, MO
    I am finishing off our basement laundry, and currently there is a 3" stack coming up out of the floor. The trap is under the concrete. Is it acceptable to reduce the pipe size to 2" in order to hook up to a washing machine outlet box, or is there a outlet box with a 3" spigot or hub connection? I fall under IRC here - they still go by the 2006 edition.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The standpipe with trap can be 2", and needs to be above the floor. This can connect to the 3" line going into the floor. The trap below the floor will need to be removed.
  4. Terry
    Aug 17, 2004
    Between the 3" stack and the p-trap, you will need a vent.
    Trap above the floor.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I do recall another member posting here that the 3" standpipe with the trap in the floor is specifically permitted by a local Missouri code. I didn't believe it at the time but did find it in the MO code.
  6. mikeygstl
    Apr 17, 2012
    Saint Louis, MO
    I do know the 3" stand pipe is permitted, with a trap beneath the floor, as it was inspected and passed justa few months ago. The problem I am having is that I now need to find a way to connect this stand pipe to a 2" washing machine outlet box.
    I'll talk with the inspector this afternoon when I pull the permit and report back what I find.
Similar Threads: Laundry stack
Plumbing Code Questions Basement Laundry Room Plumbing Jan 28, 2015
Plumbing Code Questions Venting lower level laundry Jul 18, 2014
Plumbing Code Questions Adding a utility sink to a laundry room Nov 13, 2012
Plumbing Code Questions stack & toilet vent question Oct 30, 2015
Plumbing Code Questions Waste stack size May 13, 2014
