jgold47
Hi All -
Here's what I've got...
my laundry sink seems to be dumping directly into a old main stack (I think I'm describing this right). Recently, we've had issues with the wet vent in the floor backing up on heavy usage days. We've attributed this (with a scope) to a partially blocked main drain that we are imminently getting jetted clean. However, even when things were/are normal, we have a couple of issues with the tub. It surges and gurgles like crazy, which when the tub is fully loaded and draining (I think) causes the wet vent infront of it to spill over, and we can often smell sewage which despite the sink having a trap (im guessing is from the trap getting sucked out).
so two very different questions related to getting to an answer of how to keep this thing running smoothly...
1. would adding an AAV (after the trap) help? The line doesnt seem to be vented anywhere else, and I'm not 100% sure this ties directly to the main stack which is in a different part of the basement and where the vent is. If nothing else, would that help smooth out the flow of water into the drain and limit the surging?
2. is there a way to 'slow down' a drain, in that if the tub drained out slower, the line could better handle this?
I've contemplated this for a while, but we've only had issues with back ups for the last few months.
Open to other suggestions as well.
