We are new to our house and new to the whole well water/sump pump/everything pump living, problem is our laundry tub which had a pump on the bottom drain, will drain the water when tub fills up 3/4 way, but then after the tub is 95% empty the pump will turn off and on every 2 seconds, I found if I pinch the tube going from one part of the pump to another, it will stop it from turning off and on, till the next time the tub fills up? Thanks in advanced, Jon
