catnip2377
Hi,
Great Forum. Lots of good info on here.
We are currently redoing our laundry room and will be moving the washer/dryer to an adjacent wall.
I have to move the drain/water lines about 5' from their current location.
Our current washer/dryer is an all in one stacker about 7-8 years old. We are replacing it with a front load pair.
My question is in regards to the drain. The current drain size is 1.5". The drain runs down into the concrete slab. I have no idea where it runs to from there. From reading here (and other forums) it seems that 2" is now recommended. It would be a big task to try to break up concrete/take down walls etc to change it all to 2".
I have never had an issue with our current machine draining into the 1.5", but now is the time to change what I can.
Does it help any/make any sense to use 2" from the new location to where the 1.5" pipe goes into the slab? This would be approximately a 5' horizontal run plus +- 4' vertical to the laundry box.
Thank you for your time. Hope that makes sense.
