Lantern Style lights outside. Work box?
Discussion in 'Electrical Forum discussion & Blog' started by sandyman720, Sep 13, 2007.
  1. sandyman720
    sandyman720 New Member
    Mar 5, 2007
    I am going to have outdoor lantern style lights on the outside of my addition by the side of the sliding patio door.
    New construction. Do I cut a hole and then install a work box at the location or do I do something else? :confused:
    Thanks
  2. jadnashua
    Box in the wall...light attaches to the box. Make sure to anchor the box well.
  4. sandyman720
    Mar 5, 2007
    Should I get a circular box or a regular rectangle workbox?
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Whatever the fixture will cover...
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    314.27 Outlet Boxes.
    (A) Boxes at Luminaire (Lighting Fixture) Outlets. Boxes used at luminaire (lighting fixture) or lampholder outlets shall be designed for the purpose. At every outlet used exclusively for lighting, the box shall be designed or installed so that a luminaire (lighting fixture) may be attached.
    Exception: A wall-mounted luminaire (fixture) weighing not more than 3 kg (6 lb) shall be permitted to be supported on other boxes or plaster rings that are secured to other boxes, provided the luminaire (fixture) or its supporting yoke is secured to the box with no fewer than two No. 6 or larger screws.
  7. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Depends on the fixture. A surface mounted pan box is the easiest IF the fixture will cover it.
  8. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    And there is enough cubit inches in the box for the conductors that enter it
  9. Alectrician
    Jun 15, 2007
    Don't YOU start with me either :)
Similar Threads: Lantern Style
Electrical Forum discussion & Blog Box for Lantern style lights? Sep 26, 2007
Electrical Forum discussion & Blog Old style 220 (3 wire) to new style (4 wire) connection Sep 3, 2011
