"Landlord Special" won't seal.
Discussion in 'Toilet Forum discussions' started by rayce00, Jan 12, 2006.
  1. rayce00
    rayce00 New Member
    Jan 12, 2006
    Yes, it's a cheapie. I have tried 2 plain wax rings and now a reinforced one...I still can't get a seal, the carpet around the front base still shows moisture. Is there anything (trick of the trade) I can try short of replacing the entire fixture?
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    leak
    Does the toilet wobble?
    Check for a leak between the tank and bowl.
    Check the supply pipe.
    Carpeting will make it harder sometimes to nail it down sometimes.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Why do you think it is the wax seal?
  5. jadnashua
    If the toilet rocks at all, it will leak regardless of the number of wax rings....so, you need to check that first. It is not uncommon to need to shim the toilet to keep it from rocking, especially on older structures that have seen their share of leaks. You need a little finnese,as if you shim after smushing it down, you are likely to mess up the wax seal. So, set it without the wax, shim it, then remove it carefully so you don't mess up the shims, then wax ring, then set it back down on top of the shims and cinch it down into the wax.
Similar Threads: Landlord Special
Toilet Forum discussions Legal/landlord issues... Is it me or my low flow toilet??!! May 24, 2016
Toilet Forum discussions Best toilet for a landlord wanting to avoid problems with toilet overflows? Jun 13, 2013
Toilet Forum discussions Landlord seeks good quality, affordably priced HET toilets for Tucson duplex Dec 14, 2012
Toilet Forum discussions What to tell a landlord? Nov 5, 2007
Toilet Forum discussions leak/landlord issues Jan 17, 2006
